I changing fluid in my Tremec TR-3650 that is in my 2004 mustang, there is a lot of controversy on which fluid to use in it. Some people say to use GM Syncomesh or Mobil 1 synthetic ATF and other say to stick with a conventional Dex III / Mercon fluid. The Ford manual says to use Ford Mercon ATF which is not being made anymore. I do not want to use the new Mercon V that ford said replaced regular Mercon fluid.
Because of the different blocker rings and syncros used in the trans Tremec recommended he use of a Dex III/Mercon fluid and suggested a Texaco/Havoline ATF. People say using a full synthetic or syncromesh can ruin the linings of the syncros in the trans. Having said that I would like to stay with a conventional fluid.
Who makes the best Dexron III/Mercon fluid, and are these listed below a conventional fluid?
I found Havoline MD-3, Chevron MD-3 and also Mobil 1 ATF D/M (Not the full synthetic multi-vehicle ATF that you find in stores)
Havoline MD-3
https://www.amazon.com/Havoline-22185472...s=havoline+md-3
Chevron MD-3
https://www.amazon.com/Chevron-39770-Automatic-Transmission-Fluid/dp/B0097SBAR8
Mobil 1 ATF D/M
https://www.zoro.com/mobil-mobil-atf-dm-...mp;gclsrc=aw.ds
Havoline MD-3
Chevron MD-3
Mobil 1 ATF D/M
