Originally Posted By: clinebarger
Put Contacts, Plunger, & Brushes in it or at least check the condition of the Brushes!.......And run it another 265K! ...... Contacts are the most common failure.
Exactly. The contacts under the plunger are the biggest problem. They are all pretty much the same among Toyota/Lexus and simply replacing them usually solves any starting problem as they tend to wear down and not make good contact. The starter on my daughters Corolla was factory original, when it started the 3-4 attempts before cranking routine, I went to the junkyard, found a Toyota Camry with a rebuilt starter in it, took it apart and grabbed the contacts. A couple bucks out the door and went home and removed the starter, took the solenoid apart (its super simple, just a couple screws), installed the new contacts, cleaned up the plunger a bit, and put the same starter back in. It still attached to the same 357,000 mile engine it was installed on and I have no plans to replace it as it cranks great.
