Originally Posted By: bbhero
I have put up the code already... it's in the above posts. 022215AB 20:01. I think it means it was made on the 222nd day of 2015. Which is before M/H took over the manufacturing of the Carquest line of filters.
I don't mean to be coming off like I'm giving you a hard time. I am sorry if it seems that way. I don't mean to. Just hard to not seem like a jack donkey typing stuff at times
If we were in person this is a ton easier to avoid that perception.
You're right, my bad, I didn't see it. This means the Premiums would still be safe to use, & I can never find anything cheap enough to use the $5 off $20 code on! Puro codes usually start with a letter, I didn't recognize the baseplate.
