Originally Posted By: A_Harman
Originally Posted By: carock
1. Thermally coating the exhaust valve face reduces its temperature several hundred degrees. I only know this because David Vizard told me so. I figure David Vizard knows his stuff and knocking a few hundred degrees off the valve temperature has to be a good thing for longevity.
I'd think twice about thermally coating the exhaust valve face. That will turn it into a hotspot in the combustion chamber and make the engine more susceptible to detonation or preignition. If you want to lower the valve face temperature, put beryllium copper valve seats in the cylinder head.
Wouldn't using sodium filled valves accomplish the same thing, but enable you to use steel or iron valve seats?
