Best way to store ladder
Fiberglass ladders are best stored inside. I have a decent size garage, so I center the ladder under my Jeep length wise and drive over it. As long as you have the room and ground clearance it works well. It's not in the way, and it lays perfectly flat. If you plan on wall mounting it depending on the size of the ladder it can bow a bit if you don't use enough brackets. I can't comment about the Amazon lift I never used one.
If you store it under a deck or behind a garage or anywhere outside, lock it up so a thief can't use it to gain access to your second story windows.
All good points. I put it on the wall. I used a Matrix wall system. I anchored it in 4 studs.
I was nervous if I left it outside. Now to finish organizing the garage.
