Originally Posted By: Jimzz
If you get a C5 get a 2001 or newer. 01 was a update year that fixed and updated things from the first several years.
I've heard other people say this...what were the problems with the pre-2001 models that were corrected in '01?
They updated the engine, fixed the suspension issues (mostly first year), and some other small items. 2001 was also the first year Stabiltrac was standard so that alone was worth it IMO. But 2001 had the most updates/fixes of any year for the C5
2001
* Return to 28# injectors for all models.
* Second Generation Active Handling
* Nassau Blue discontinued
* Alternator 'clutch' pulley added on A4 cars
* New soundproofing + foam in all cars
* Smaller keyfob
* Electrochromic dimming rearview and driver's mirrors
* Lighter AGM battery
* Thickness + Material in Convertible change
* Chrome exhaust tips for coupe + Convertible
* 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
* LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
* All Corvettes now have the LS6 intake manifold
* All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
* LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
* Hardtop/FRC discontinued
* Stronger synchros in all transmissions
* Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
* Metal valvestem caps (late year)
* Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
* Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
* Introduction of the Z06, which has as differences:
* Hardtop body style
* Rear brake ducting
* Screened inlets on front fascia, without foglights
* F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
* New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
* M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
* Titanium exhaust system
* Lightweight windshield
* New, stronger clutch with redesigned master + slave cylinder
* Stronger rear differential (shotpeened ring gear)
* Red brake calipers (otherwise identical)
* Transmission overtemp warning light on DIC
* 6500 redline gauges with special checkering + Z06 font
* Redesigned PCV system to help combat oil burning
* Red LS6 Fuel Rail Covers (FRC's)
* FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
Wow, that's a lot of upgrades! Now I see why I should be looking for an '01 or later model!
