Hi,
Freedom Lift required only Chevron Clarity Hydraulic Oil AW ISO 32.
We can only find 5gallons quantity.
I found Amsoil Tractor hydraulic oïl in small quantity (1 liter) :
http://www.amsoil.com/shop/by-product/hy...EA#ReviewHeader
from user manual :
Do NOT use any hydraulic fluid other than that provided by FreedomLift® Using any other fluid can cause the lift to malfunction and will void all warranty. Use only Chevron Clarity Hydraulic Oil AW ISO 32.
Level is low but not enough to put 5gallons ....
Does Amsoil Tractor Hydraulic have the same specs has Chevron Clarity Hydraulic Oil AW ISO 32 ?
from user manual :
