Replacing clutch hydraulics on the newly rebuilt saturn. The plastic wings on the end caught the edge of the case and the pull pulled free of the slave and dropped in and down beside the flywheel.
I really did not want to have to remove the struts and suspension and slide the trans apart to get it out. I did a bit of work with an angle grinder and a chainsaw file to get it out.
Man it was a pain to fish out, i used 1/2 of an old piston ring to fish it out.
I knicked the flywheel teeth a bit, hopefully it's not a problem.
