This is about the only realm of the tire world that has me pulling out my hair. Every other application seems to have plenty of flavours to choose from, but with trailer tires, not so much.
The trailer in question, if anyone here is familiar with, is a 2010 Keystone Cougar 322QBS. It has the original factory installed tires, very little use as evidenced by the almost non-existent tread wear. And of course, DOT date codes from late 2009, putting these tires at overdue for replacement.
And that's where the problem for me is. What are some viable replacement options?
First, trailer specs:
Dual axle, with GAWR of 5,200 lbs per axle
GVWR of 11,860 lbs
OEM Tires: Power King Towmax STR II, ST235/80R16, Load Range E (3,520 lbs @ 80 psi)
Tire placard: 235/80R16E
I can already say what I DON'T want to go with as replacements:
- Power King Towmax STR II (or any other rebrand of this) - this tire has attained infamy and earned the nickname of "China Bombs".
- Goodyear Marathon - another infamous trailer tire, lovingly known as "Marabombs"
Here are some maybes, and possible issues as I see it with them:
- Sailun S637ST in either ST235/80R16 or ST235/85R16: Surprisingly, this Chinese brand seems to have earned a good reputation in the trailer world. They seem to be overbuilt, and tire weight is much heavier than others on the market. Other tires in the S637 line are truck tires, but there are rumours (no way of knowing what the truth is) these two sizes were marked "ST" simply to be classified into a lower import tax class. These tires require 110 psi to achieve max load capacity of 4,080 lbs. Could this be an issue with the OEM rims?
- Maxxis ST Radial M8008 in ST235/80R16 LRE: A Thai company (but who knows where the tire is made), seems to be a direct replacement, rated 3,420 lbs at 80 psi. Another tire that seems to have earned a good reputation in the trailer world.
- Carlisle Radial Trail HD in ST235/80R16 LRE or ST235/85R16 LRE: My personal confidence in Carlisle isn't as high, as I recall them not fairing to well when I previously researched a much smaller trailer tire, but these also seem to have a good reputation. The 80s have a capacity of 3,520 lbs at 80PSI, and the 85s a capacity of 3,960 lbs at 80 psi.
- GT Radial Maxmiler ST in ST235/80R16 or ST235/85R16: Don't know much about this tire, but GT Radial is actually Giti from Singapore, and seems to have a presence in Canada in the cheap tire market, but not so much so in the US. Appears to be well received here for their passenger car/light truck tires. Not sure if this is one I would take a chance on, without knowing much about them. The 80s have a capacity of 3,520 lbs at 80PSI, and the 85s a capacity of 3,640 lbs at 80 psi.
- Possibly consider Kenda or Duro, they seem a bit better than others, based again on my past research of smaller sizes, and also presence in other tire markets
These are all ST offerings, and so aren't my ideal, as I would really rather move to LT.
But moving to LT, while staying as close as possible to the OEM size in 16", seems to yield at best just shy of 3,100 lbs capacity.
Am I confined realistically to the ST choices? If so, which are reasonable options?
GVWR of 11,860 lbs
