I bought the Innovited HID kit on amazon bi-xenon. It has a 4.5/5 star rating with about 1,500 reviews. Has lo and hi hid beams. Had them installed today. You know how the lo beams are supposed to be pointed to the road so that it doesn't blind on coming drivers. Well these lo beams point relatively high which I can see will be a problem for on coming drivers. It also does switch to hi beams which point even higher. Is this the bulb causing this problem?
https://www.amazon.com/gp/aw/d/B00FC22PV...&ref=plSrch
