Back in 2012 I replaced the factory (from 2000) upper and lower hoses on the Cherokee along with the water pump and fan clutch. No reason other than a "just because" - the cooling systems on these Cherokees are very sensitive and I didn't want to have that leave me on a trail when something gave out.
I have noticed the Jeep has been losing some coolant lately. I didn't think it was a cracked head because I could smell coolant but couldn't find it leaking anywhere significant. This weekend after a bit of a highway run, I stopped to get some gas and coffee and let it idle when I ran in the store - was with some friends - and came back out and there was big puddle of coolant.
Turns out the upper radiator hose just started bulging at the thermostat end and spraying out around the hose clamp. The hose clamp is tight but it seems that the hose is just coming apart and dryrotting after 4 years.
Is this normal for aftermarket (Napa) hoses to only last 4 years? I have put maybe 40,000 miles on it from doing the hoses and pump last time.
