If you're already using what is IMO the premier HM oil, then why would you want to switch?
Also, if the engine has had regular maintenance, it doesn't need a good cleaning.
It's already as clean as any old engine is going to be.
What risk do you think would be involved in moving from one fully formulated oil to another?
If the principle function of motor oil is to lubricate the engine and to avoid leaving deposits behind, then any motor oil of the last four or five API specs will perform just fine in your old engine or one of mine.
You want to try PYB? Go for it. No harm or risk involved.
