I have a 2005 Sienna LE FWD with 160,000 miles. About 2 months ago or 3,000 miles, I noticed a few drops of ATF on my driveway. I cleaned everything up from underneath the van and figured out that the leak was coming from the portion of the transmission where the two halves are bolted together. I put the van in a transmission shop and they took out the two bolts and cleaned everything up. They then applied a sealant to both the inside and outside of the transmission halves and installed the two bolts and tightened everything up. After picking the van up and driving it for 40 miles, I noticed the leak had started again. It only leaks about 2-3 drops every 24-36 hours. Any suggestions on what I could do to seal this part of the trans?
The first photo is when the van came back from the shop and the next photo is after driving the van and letting it sit overnight. Also any ideas on why this leak would start after 157,000 miles? The ATF is changed annually and the fluid is sent out to Blackstone for analysis. All reports on the ATF have come back extremely positive, so the fluid is in great shape. The ATF is Amsoil.
