donnyj08
Thread starter
Originally Posted By: AMC
Originally Posted By: donnyj08
The BelRay I have in there now has a tiny layer of foam if you check it immediately after shutting it off. It is about 1/4 of what I saw with Delvac. I also have had 0 false neutrals since I put in a MA2 rated oil. I was getting false nuetrals on quick downshifts with Delvac.
I have some 10w40 Shell advance on hand next. After I run through that I'll give Rotella a try and see how it does.
The manual says to wait a few minutes after shutting off before checking the oil. By then it is always free of foam.
Interesting. Maybe the XSR engine is a little more picky about its oil selection. Perhaps too picky to bother using an HDEO? Rotella T3 15w-40 has no moly and a slightly weaker additive pack than delvac or delo. I wonder if that would solve the problems you had with delvac.
I'm not sure. I was hoping Delvac would have been perfect because the price is great. But shift feel wise the BelRay is much much better especially on downshifting.
