I am going to do a timing belt job and replace all the engine oil seals. I often read of taking some emery cloth to polish the shaft just a bit before installing the new seal. However, I never learned what grit would be considered "emery cloth". I have various fine grits of wet + dry sandpaper so would like to know what might be a good grit to use to polish the shaft ends before installing the new seals?
I know one does not want to introduce new scratches; just to polish the metal to remove anything left by the old hardened seal and smooth up the shaft end as needed.
I guess this same question would apply if one was to replace the connector rod bearings, some use emery cloth to polish the crankshaft surface before installing the new bearing but I never read about the grit level.
