if I want to drop the pan and drain my tranny to change out the old fluid, how many quarts do I need? and what is the suggested brand/type of new fluid to use? thanks
but is the castrol vi or maxlifevi ok to use instead og oem and not sure about quarts...it says 7 qts service fill or 13 qts for a complete drain ? what would dropping the pan be ???
Dropping the pan will yield about 5 qts, dropping the filter will dump an additional 2-2.5 qts. Maxlife is fine in these transmissions.
Have you done one of these before? Its an easy unit to do a line off exchange on, a lot cleaner too.
