I took the blade off my lawnmower to sharpen it and put a new starter cord in and now the motor won't turn.
I can barely pull the motor motor through a revolution using the blade (with the spark plug disconnected of course) but can't turn it at all with the starter cord.
Given that I didn't touch the motor I can't see what could have caused this. My initial thought was the engine was hydrolocked with oil from being on its side so I pulled the plug but this made no difference.
It's an old 3.5 hp L-head Tecumseh motor on a generic 20" push mower. I figured someone here might have run into this issue before and know the solution.
