Originally Posted By: George Bynum
For industrial applications, hydraulic oil is undoubtedly the better product. Cold (below 40F, 5C or so) startups are extremely rare so the viscosity grade can be selected for 15 cSt or so at operating temperature without worrying about startup cavitation. Temperatures are usually controlled, so we don't have to worry about it thinning to 6 or 7 cSt. Realize that industrial systems frequently run 24/7/360 ... over 50,000 hours a year. Motor oil is almost always changed in less than 500 hours ... 1% of a year.
It's a tradeoff. I have detractors here ... I like pre-Dexron VI ATF for the excellent (200+) VI. The newest products are just too thin for hydraulic systems ... in the energy conserving emphasis.
I took a quick look on Eaton's and Sundstrand's websites; Eaton recommends 20W20 hydraulic oil, whatever that is. Sunstrand says "Ratings and data for Sauer-Sundstrand products are based on operating with premium hydraulic fluids containing oxidation, rust, and foam inhibitors. These premium fluids include API CD engine oils per SAE J183, Type F automatic transmission fluids, power shift transmission fluids meeting Allison C-3 or Caterpillar TO-2 requirements and certain specialty agriculture tractor fluids."
As for the why, I'm 98% sure it is because there are very few multiviscosity hydraulic fluids.
George, we are no longer "Sundstrand" or even "Sauer-Sundstrand" but the manual you are quoting from has changed a little from back in the days we used those names. We are now "Danfoss Power Solutions" and have totally dropped the Sundstrand name. For use in our products we really stress to use a premium anti-wear hydraulic fluid that meets the viscosity requirements for your operating conditions.
I was able to touch base with a Hydro-Gear engineer this morning on why they specify engine oil. The summary to his response is that it is good enough, cheap, and readily available.
If you are using Danfoss Power Solutions components, I can say without a doubt we prefer you run them in premium hydraulic fluid! We use and test with only hydraulic fluid in our labs.
Here is the latest cut from our fluids manual that can be found here:
http://files.danfoss.com/documents/Hydraulic%20Fluids%20and%20Lubricants,%20Technical%20Information/520L0463.pdf
The rated data which we publish in our Technical Information and Service Manuals are based on the use
of premium hydraulic fluids containing oxidation, rust, and foam inhibitors. These fluids must also
possess good thermal and hydrolytic stability to prevent wear erosion, and corrosion of the internal
components. For some applications good anti-wear additives are required.
The following specifications / standards are equivalent to the basic requirements for fluids used in
Danfoss Power Solutions components:
• Hydraulic Oil ISO 11 158 - HM
(Seal compatibility and vane pump wear resistance per DIN 51 524-2 must be met)
• Hydraulic Oil ISO 11 158 - HV
(Seal compatibility and vane pump wear resistance per DIN 51 524-3 must be met)
• Hydraulic Oil DIN 51 524-2 - HLP
• Hydraulic Oil DIN 51 524-3 - HVLP
• Automatic Transmission Fluid ATF A Suffix A (GM)
• Automatic Transmission Fluid Dexron II (GM), which meets Allison C-3 and Caterpillar TO-2 test
• Automatic Transmission Fluid M2C33F and G (Ford)
• Engine oils API Classification SL, SJ (for gasoline engines) and CI-4, CH-4, CG-4, CF-4 and CF (for diesel
engines)
• Super Tractor Oil Universal (STOU) special agricultural tractor fluid
