Originally Posted By: 4WD
Questions for the turbine spinners - no, not LM2500's - but GE-90.
In Tokyo the other day - and a tech pulls up to a B772
He's in a man basket - and has a couple cases of Mobil synthetic. This guy poured bottles for a while.
(Gallon jugs maybe).
Questions:
What would the GE-90 engine hold? (Not a 115) ...
How much would they consume (13 hour flight in this case). ?
Not sure about that particular airline's choice of oil. However, most modern turbine engines can use all of the commonly available turbine oils. Mobil Jet II is an older product that is very common and approved in nearly any engine. Mobil 254 is a more expensive, high temperature (HTS) gen III version of turbine oil. 254 (and other HTS turbine oils) is/are hard on seals and "O" rings, so it's use in older engines is generally frowned upon.
http://pds.exxonmobil.com/USA-English/Aviation/PDS/GLXXENAVIEMMobil_Jet_Oil_254.aspx
Most modern turbine engines use very little oil in flight. Also, the oil is typically not ever changed. It's not unusual to go 40-100 hours between adding oil on modern engines.
Turbine engines do not have piston rings or valve guides that can lead to oil consumption. The oil is pumped to bearings and scavenged from bearings via another pump. The labyrinth seals are pressurized with air, so it's very unlikely that any oil can overcome the air pressure and get through the seals.
The specification for modern turbine oils is: Mil-PRF-23699 (with a revision letter such as "F" or "G" after)
As you might expect, every once in a while, we see an engine that simply consumes a bit of oil. Most of the time, it's evident on the outside of the cowl. Either at the bottom, or by the breather outlet.
