What is the best method to change the fluid on a 14 Mustang GT? My tranny has the thermostat so from what I've been told, it's almost impossible to flush this transmission(6R80)
This car has the very short dipstick which is very hard to access unless you have a lift.
Does anyone know if you take out the dipstick with the car off, will fluid come pouring out the hole? My plan was to remove the pan and measure how much fluid came out and replace with the same amount but I don't know if the car has to be running to be able to fill the tranny back up without it all coming back out the dipstick hole.
Wayne
Wayne
