'06 G35 6MT w/ VQ35DE Revup.
I have a fuel smell coming from the Evap canister most of the time. There are no CEL's. The valve at the canister was replaced at around 90K due to P0456.
If I command the purge valve to open using CONSULT II, it will open the specified duty cycle and pull the fumes out of the canister. If I log data while driving over hundreds of miles, the purge valve is never commanded to open. I can drive for a day or two with the valve commanded open and the fuel smell will go away for a couple hundred additional miles.
I have another '06 Infiniti, if I log data while driving, basically anytime the engine is up to temp and I am off idle, the purge valve is open some percent.
I have verified that the valves all work properly, there are no leaks, the pressure sensor was swapped between vehicles and made no difference. And there are no CEL's or stored codes. It has been like this for about 10K miles and never a code.
What am I missing, I assume there are other things that need to be ready. The ECU reports correct engine and air temp, the car runs fine. The ECU reports throttle closed, % and WOT properly.
Is there a common thing that would cause this?
Thanks!
Thanks!
