Originally Posted By: Shannow
TCW3 is outboard two stroke and "ashless", so it doesn't generate metallic ash deposits during combustion. typical air cooled "racing" two strokes, while sounding flash, have the possibility of causing these deposits.
I wait until the Valvoline semi synthetic is on special at supercheap, and buy a big bottle at a time.
The link that you just posted makes sense.
I've read papers that indicate that friction modifiers in fuel make it to the region of the oil film around the top ring also, so may genuinely provide Upper Cylinder Lubrication.
Got a Navara with the ZD30, and have used a couple hundred ml religiously every tank full since new.
That had me remember a forum of Corvette owners. They experimented with oil for a top end lubricate to foster extra mileage. They determined that Pennzoil Synthetic Marine 2 cycle mixed at 3oz per 15 gallon was the sweet spot
