The 2007 Civic I recently inherited had a problem with the passenger side wiper where it refused to make contact with the middle portion of the windshield. At first, it seemed as though the wiper arm would have to be bent in order to regain full contact, however, upon further investigation, the wiper arm's hinge, due to its exposed design, had some moderate rust which prevented the blade from making full contact. After spraying the hinge at the bottom of the arm with silicon spray lubricant and working it around a bit, the wiper hit the windshield with a satisfying thwack, wiping the windshield perfectly.
This may also work on other Hondas/ vehicles with an exposed hinge, particularly newer models. Hope this helps someone avoid replacing an entire arm.
