Originally Posted By: Benedikt
Same kind of 2016 Passat 1.8TSI, similar question:
I'd been using M1 0w40 (which on the current bottles says "meets VW 502 and 505") in its otherwise identical predecessor, and was planning on using it in this one too (in fact, I just replaced the mystery factory fill with it).
Going to pick up oil for our 2012 TDI (needs 507) from the dealer, I find that instead of Castrol LL03 for $8.something, they now stock M1 ESP 5w30 for 6.80, which I was vaguely aware of but had never seen on a store shelf. On the bottle, it says it also meets VW 504.
So per spec, either one of these would work for the TSI. Southern weather here; the extremes are several months of rare low 100s, and a couple of months with frequent frost but rarely below 20.
The price difference is less than $20, and both are conveniently available without worrying about shipping. Given the always-on turbo setup, I intend to run shorter OCIs.
(Interestingly, the ESP bottles are 1l, labeled in English and German only, and no indication of origin - but they are not VW-labeled like the Castrol was.)
Is one better than the other for this engine?
If they're about the same, does mixing make sense? 5-qt jug of 0w40 from WM and the last 1-1.5 qts from quart bottles of ESP 5w30 would be a convenience compromise between pouring it in the car and pouring old oil back into the bottles.
Keep using M1 0W40 FS although my preference would be Castrol 0W40 in 1.8TSI
M1 5W30 ESP is really good oil, but until we move to Ultra low sulphur gas apparently on 01/01/2017, I would stay away from VW 504.00/507.00 oils.
I sue that oil primarily in my BMW diesel (Now use Valvoline just to try) and it is really good, but it is performing good in diesels in the U.S. since diesel fuel is low sulfur. I tried M1 5W30 ESP in my VW CC I had, and by 3K TBN was almost gone.
Thanks. But do I understand correctly that at the cost of a 3k OCI (which I intend to do until 10k anyway, and two OCIs would last well past the ULS fuel introduction), M1 5W30 ESP would minimize carbon deposits?
It should minimize carbon deposits, but there is more to it. Hard driving helps, Low NOACK helps (and M1 5W30 ESP apparently has ridiculously low NOACK). Also, it has to do with composition of additives, and I think Castrol is better there when it comes to depositions (NOT Castrol 5W40).
