Originally Posted By: HKPolice
1 quart top up on an engine that takes less than 4qts? That TBN is not accurate at all. Try sampling before topping up next time.
Good point!! But the other side, there was almost 1 quart of used oil still in the engine after the drain. I was able to pour only 3 quart of fresh oil into the sump.
