You use a bypass filter to keep the oil clean. You add oil to a Frantz filter by 3000 miles. Mine takes just over 1/2 quart. Despite what you read elsewhere in these bypass filter threads, the filters really do make your engine last longer, providing nothing else knocks it out first, like a blown head gasket. The bypass filter is not just about making your oil last longer.
The bypass filter effectively makes your oil last longer. It also keeps the oil very clean the entire time you are running it. It also prevents the flush of wear particles that comes from changing all your oil at once. According to the latest tribology and plating theories expounded on this site, changing your oil actually causes more wear than leaving it in. My tests show no measureable increase after changing 15% of your sump oil, therefore the amount of oil added with a bypass filter change is not causing this accelerated wear that comes from adding 100% new oil. Go figure. I am not sure I am on board with this "new oil causes more wear" theory, but there is some convincing evidence behind it.
Anyway. there were older tests performed that showed engine wear is directly attributable to the weight of contaminate particles in the oil. So the more particles you keep out, the less wear you get. Better filtration equals longer life "all other things being equal". The filtration systems sold on cars these days are designed for "long enough life". If you want longer life you do what the big trucks do, you add better filtration and larger sumps.
