Originally Posted By: Riqrat
This question has popped into mu head after reading and hearing many people make statements like:
"My engine is clearly quieter than it was."
"It runs much cooler."
"I notice less vibration..." "..my mirrors don't shake as much" "...you can now stand a coin on it and it does not fall."
"The oil is staying cleaner longer with the same filter and oil I've always used."
etc. etc.
Many say you only need to change your oil and filter every x miles and nothing else. If this is true, then why are others noticing the above? And no, this is not placebo.
I have a 2002 Honda Odyssey VTek 3.5 with 177k miles on it. The idling is insanely quiet and smooth for an engine of this miles that has travelled the country and carried large loads at times. This after I tried out an additive. Called my wife out to the garage and said "babe, you gotta check this out." It's her van. Too early to tell how long it will last like this but it clearly runs better right now than with just oil and I use high quality Shaeffer and Amsoil oils on our vehicles.
What say you?
Guess you are talking about me???
My dime. My truck.
I have been told by close friends that are mechanics and also seen my lower end of my engine myself to see how the bearings, and such are in great shape after what I use as my concoction. My mileage and power are great for an already torquey engine.
The really great mechanics that know engines might not being in a site speaking their truth about certain additives that do and do not work because they are making a good living if they are in the right area and shop to take the money like "candy from a baby" to fix your engine failure and other misc issues.
Thanks again for noticing my posts. I'm just letting some people online that it doesn't hurt to try. Trial and error.
What year, what kind of mileage, and where do you buy your low tier cheaper fuel at, ______?
The reason why I got to see my under my engine on a Cherokee was because the 4.0 are known notorious for having the rear main 2piece seal start to leak. When I had mine replaced it was at a bit over 200,000miles. I had the oil pump replaced and it has been a fun ride. Especially since I have had it for awhile since 90,000miles.
Kudos to you.
