After being on the site for years I finally decided to run a UOA. With a new Mazda that has a new (to me) OLM, I figured it was the perfect time. I first changed the oil at the 1,169 mile mark to get any of the immediate wear materials out of the engine. After seeing the results of this change, I'm doubling down on that practice (unless told otherwise from the manufacturer).
This is my first Mazda with an OLM. I had a '14 CX-5 with the same motor but the manual only allowed for 7.5k mi/6 month or 5k mi/4 month OCIs, given that it was under warranty that is what I adhered to. The new CX-5 gives a third option, a OLM option. Given that I use the OLM in the Monte and that I like to stretch every dollar I naturally decided to simply follow the OLM and be done with it. The only caveat to the OLM is that if the indicator does not illuminate but you've reached 10k miles or 12 months, then it's time to change the oil. Well, I reached 8,951 miles in approximately 4 and a half months and the OLM still read 60%. I decided it was time to do an oil change and get a UOA.
Other than the initial wear, everything looks good. I think I'll run my next change for around the same amount of miles and get a 2nd UOA to see if the numbers start trending downward. If they do, I think I'll be hitting the 10k mile cap in no time.
