I need to adhere some thin reflective aluminum material on some high density foam that's used in the engine compartment. This will help shield the heat radiation from the exhaust header to keep the foam from degrading.
I'm considering just using some contact cement which can typically take ~150 deg F, but was wondering if you guys know of any other adhesives that might work better. The material is light weight, so the adhesive doesn't need to be super strong, just be able to hold the material in place.
