Hey all,
I have a 2013 WR250F and a 2006 SV650N, both bikes call for a 10w-40 oil, but thinking that a lower Winter rating would be better for my engines.
From what I know about oil, all that will be different will be the "cold" start rating. Once warm they should be the same viscosity as recommended by the manufacture, but can having a lower Winter rating cause damage to a motor? Will it not "stick/retain" as well to the bearings and other components due to being a thinner winter grade?
Are there any drawbacks or concerns to running a lower Winter grade then recommended by the manufacture?
Does having a lower viscosity indicate a "thinner" oil in terms of its physical properties, or does it just flow better?
