I assume, yes I know, the 2.5L ford motor has a block coolant drain. Can someone tell me where it is located. I've searched the manual without success and looking for it is like the proverbial needle.
Thanks
Originally Posted By: user52165
Originally Posted By: JamesBond
Is it leaking? I wouldn't mess with it if you're just changing coolant.
Why not? That's how you get all/most of the coolant (and the crud) out. Kudos to the OP.
No need to anymore.
When its time to "change" my coolant, I do a simple radiator drain & fill each oil change for 2-3 changes. Similar to the transmission fluid DIY service schedule for autos.
