Fastest MIR ever!
by parshisa
14 minutes 18 seconds ago
2003 Dodge Dakota 4.7 V8 5-speed manual 4X4
by oilpsi2high
26 minutes 10 seconds ago
Eagles are one and done..
by LeakySeals
34 minutes 14 seconds ago
Switching Oil viscosity giving Quicksilver a try
by ad244
Today at 01:54 PM
2015 Yaris oil recommendation
by BIMMA
Today at 01:29 PM
Can any one tell me who make's this air filter?
by rollinpete
Today at 01:17 PM
38 years ago today
by dnewton3
Today at 01:07 PM
PQIA - Havoline HM Synblend 5w-30
by wemay
Today at 12:44 PM
Any 2015 Corolla owners here - coolant change Q
by NissanMaxima
Today at 12:20 PM
Thoughts on 2007 Hyundai Azera for $2700
by 901Memphis
Today at 12:18 PM
run straight coolant
by slomo
Today at 11:43 AM
How much liquid is needed to hydrolock an engine?
by zorobabel
Today at 11:14 AM
Intake manifold bolts torque 11ft lb
by Ndx
Today at 10:55 AM
Orange can of death
by WyrTwister
Today at 10:42 AM
Weird Master Cylinder Behavior
by artbuc
Today at 10:42 AM
Police were called, I was shoplifting!
by expat
Today at 10:41 AM
Mobile CI-4+ in Cummins 5.9L
by MileHi
Today at 10:19 AM
How & what pistol do you carry concealed?
by callbay
Today at 10:13 AM
High Mileage Transmission Change
by toreytlow
Today at 10:13 AM
Jamison Guardian Ammo
by BlueOvalFitter
Today at 09:53 AM
toreytlow, KOlan, Tenorman, DMperfection101, WiseOne
64257 Registered Users
111 registered (4WD, 2010Civic, 901Memphis, 69Torino, 14Accent, 7 invisible), 1713 Guests and 95 Spiders online.
64257 Members
65 Forums
278546 Topics
#4171900 - 08/08/16 01:33 PM 2003 Jetta TDI Mobil 1 TDT 3000 miles
outoforder Offline
Loc: Ohio
TDI with 311,000 miles. I've used Blackstone previously for testing, but they do not quantify soot in samples. I'm not sure why my car shows so much soot in the oil. I know the purpose of diesel oil is to hold soot in suspension, but is my amount excessive?
Iron 77
Chromium 3
Nickel 1
Aluminum 13
Copper 6
Lead 1
Silicon 8
Sodium 5
Potassium 4
Molybdenum 29
Boron 100
Magnesium 681
Calcium 1747
Phosphorus 1018
Zinc 1269
Soot 0.9% E2421
Viscosity 100 C 15.6
Oxidation 20
Nitration 15
2003 Grey Jetta TDI 309,000 miles
1999 Green Jetta TDI 353,000 miles
2002 White Expedition 170,000 miles
2003 Black Solara Convertible 194,000 miles
#4171994 - 08/08/16 04:09 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
loneryder Offline
Loc: WV
To me that is a lot of iron for 3000 miles.
#4172028 - 08/08/16 05:19 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
901Memphis Online   content
Loc: Northern Kentucky
That's not high. Some people say to condemn the oil around 3%
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
1998 Nissan Altima 337k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#4172030 - 08/08/16 05:21 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
#4185014 - 08/23/16 10:22 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
Provi Offline
Loc: Dunbar, WV USA
That iron level is high. My last UOA only showed 26ppm of iron at 14k with no mark up in my 02 TDI.
http://www.bobistheoilguy.com/forums/ubb...ile#Post3799706
02 VW Jetta TDI, Mobil Euro 0w-40
15 VW GSW TDI, VW 507 5w-30
#4185092 - 08/24/16 01:56 AM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
UltrafanUK Offline
Loc: England
Both the Iron and Aluminium figures are high for such a short OCI.
I would be inclined to make sure the oil flow around the top end is good by using a major brand oil flush additive that is designed for use at idle just before the next oil & filter change.
It might also be worth trying a can of Liqui Moly Ceratec to beef up the anti wear additives, to see if that reduces the wear metals. The wear seems to be top end related (The Lead figure is OK), so there is no point using a thicker oil.
PS: If you have any oil leaks flushing can make them worse for a while due to what they call the false oil seal effect, where sludge is helping a worn or split oil seal or gasket to function. In a bad case you might need to use a stop leak after flushing.
Edited by UltrafanUK (08/24/16 02:03 AM)
Shell Ultra 0 or 5w40 or Liqui Moly 5w40 plus Ceratec every long OCI.
LM idle flush every 100K km.
#4186593 - 08/25/16 08:51 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: Provi]
KernelK Offline
Loc: PA
I wonder if the high iron is indicative of high cam wear that has plagued many of the TDI engines.
#4191452 - 08/31/16 10:47 AM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: KernelK]
outoforder Offline
Loc: Ohio
I replaced the camshaft last March and iron does not appear to have changed much. The camshaft that was removed looks to be in decent shape for 309,000 miles.
#4279306 - 12/19/16 04:32 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: KernelK]
k1rod Offline
Loc: Arizona
It's an 03 so it would have an ALH engine. There has been no cam issues with the ALH. The ALH is probably one of the most rock solid engines VW has ever built. The start of the cam problems was with the BEW 2004.5 engines. The cam lobes in those engines were narrower and under tremendous pressure. Most oils don't have the film strength to hold up to these pressures.
#4289302 - 12/30/16 08:54 PM Re: 2003 Jetta TDI Mobil 1 TDT 3000 miles [Re: outoforder]
Audios Offline
Loc: Lyndhurst NJ
My most recent report also showed high iron, on Shell Rotella T6. I believe I was in the 45 range though.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW X3 3.0i Fuchs GT1 5/40
2005 BMW M3 Liqui Moly 10/60
1997 John Deere Gator 4x2
