Fusion Block Drain Location
Nowhere NM
I assume, yes I know, the 2.5L ford motor has a block coolant drain. Can someone tell me where it is located. I've searched the manual without success and looking for it is like the proverbial needle.
Thanks
Smoky
Sure, Smoky. Here's yours:
Originally Posted By: JamesBond
Is it leaking? I wouldn't mess with it if you're just changing coolant.
Why not? That's how you get all/most of the coolant (and the crud) out. Kudos to the OP.
No need to anymore.
When its time to "change" my coolant, I do a simple radiator drain & fill each oil change for 2-3 changes. Similar to the transmission fluid DIY service schedule for autos.
