Originally Posted By: BLKROKT
dailydriver said:No problem. I'm a big believer in hard data. Put a 300ml bottle in for about 8.5 quarts of M1 0W-40. I'm trying this because with the flat-tappet design of these engines, the lifters and cams tend to wear prematurely as the oil on cold starts doesn't get to them fast enough, and they bleed out quickly on shutdown. Minor design flaw, but makes some noise as the lifters wear.
Than stay away from thin and lighweight oils ( 0w-xy or sae20/30...)
Try to get some EU vw 505.01 (full saps) or vw 507 (low saps) oil for vw PD engines...it has additive that makes oil more stay put.....otherwise you ruin cam ( PD injectors are hard on cam...lot of preasure there at cold starts-due to no oil there at cold start)
