Originally Posted By: NormanBuntz
Originally Posted By: fujirio
can you give me those reasons? would like to know more about oil for my wifes car.
Your question is really a matter of personal preference since Honda approves both 0w-20 and 5w-20 for your Element. My Ridgeline only occasionally is in sub freezing weather. It sees many more temperatures above 90 degrees than it does below 40 degrees so cold starting matters not to me. With 78K miles it uses zero oil between changes with 5w-20 synthetic blend. I don't care about the minuscule fuel mileage gain you get from 0w-20. Finally 5w-20 oils (even full syns) are more readily available at better prices than 0w-20, at least where I live.
thank you.
