Originally Posted By: joegreen
What about the stearic acid is that measured by volume or weight? Do you think it's a good idea to use or use something else?
You can obviously measure it by either volume or weight. If you want to follow your source ref, do whatever they did, but your other ingredients probably aren't the same so it probably doesn't matter much. 1-3% is a fair range, so it probably doesn't matter much to them either. Perhaps they are using a crude source which varies in its stearic acid content.
I'd do it by volume because its easier.
As to whether its a good idea, it makes sense, but so would lots of other polar organics. As I said, I'd use something cruder like tallow or crude lanolin (if you can get it). I doubt there's much advantage in using pure stearic acid in this application and I'd guess it'd add cost.
I use a mix of diesel fuel, hydraulic or motor oil and vegetable oil, roughly 1:1:2 by volume last time. Seems to work, but your stuff sounds like it might be better.
I tried mixing diesel with it last time but I found the formula to be thicker and longer lasting without the diesel. After the diesel evaporated there was not much waxy oil left behind. I used the diesel mix last time because my old oil undercoating gun had a really small pickup tube so it couldn't pick up to thick of a formula. My new undercoating gun has a 5/16 pickup tube that allows me to pick up an almost grease like formula which I prefer.
I don't have any spray equipment, so I use a plant sprayer. This means I have to use a thin mix, which probably leaves less long-term residue. OTOH it may be more penetrative, which may be more important. It does seem to creep along seams quite well.
