Jetronic,
If an oil contains some PPD, then the CCS and MRV tend to move it tandem. If you drop the CCS, then you automatically drop the MRV. So it's nigh on impossible to pass the CCS and fail the MRV in the way you suggest.
I can't remember exactly what happened as it was several years ago. I do sort of recall however that the customer (no names) wanted something that was basically impossible in that they wanted to tag GF-4 fuel economy onto an SL oil which also needed to meet A3/B3 (ie needed to meet 3.5 min HTHS). I had carte blanche from the customer to do whatever was needed to be done to get the pass so I probably did something dramatic and halved the usual CCS. What I forgot was that in rough terms, CCS doubles for every 5C you drop the test temperature so my oil just dropped into being an on-grade 5W30. Hence the grief from upstairs!
The irony was after all this got aired and after a lot of shouting, I got a legit pass...which the customer then completely ignored and went with what he wanted in the first place. Such is life...
