I finally used some Delvac 1300 I bought before I even had the car I've put it in, so it's probably 2009 vintage oil.
It was BOGO with a Mobil MIR, so it came to .79/qt IIRC.
Anyway, these jugs have a neat little built-in pour spout.
You turn the main cap counterclockwise and the second cap pops up with a couple of little rings. You then pull the little rings up and you have a handy spout. You twist the cap with these little rings off and pour the oil. You could do this without a funnel.
I've never seen this arrangement on any other brand of oil and it did seem pretty neat.
