Originally Posted By: WobblyElvis
I would say no. You can learn more by cutting open the oil filter and looking for carbon/sludge.
LOL X 2
I use Polaris labs, and they provide TBN without extra charge. I have several years history of UOA on my personal vehicles, and I don't need to cut oil filters open and guess what I think I see, or post pictures on here for accountants or retirees to comment on. I have lab reports with TBN and particle counts;
I know the internal conditions of my engines.
10000km= 6213mi Polaris isn't even interested in seeing a used oil sample until I get to 7500 miles; but I'm running full synthetic and bypass filtration, I change oil when I don't like the test lab results. My last oil change was at 16K because I didn't like the particle count.
You don't have to look very far for more information on TBN in UOA:
http://bobistheoilguy.com/engine-oil-analysis/
The TBN (Total Base Number) is a lubricant’s reserve alkalinity measured in milligrams of potassium hydroxide, or calcium sulfonate per gram of oil. In more simple terms it is the amount of active additives remaining. This number is important because combustion byproducts tend to form acidic compounds and the TBN is the acid-neutralizing capacity of the lubricant. The TBN does not decrease linearly with the time it has been in use. Example: it could start out at a TBN of 10, drop to 5 after only 1,000 miles of use, and then stabilize around 3 for a majority of the remaining service life. A TBN of
Do as you wish for your own vehicle, but there are labs besides Blackstone which consider TBN important enough it is included in their basic charges for UOA. It is my personal opinion that TBN is going to tell you a lot more about the remaining life expectancy of the oil than most anything else on a newer engine; you don't really expect to see "off the chart" wear metals, you're trying to verify that your oil is still serviceable, establish a baseline for future use, and have documentation that you're not abusing your engine. I would definitely do the TBN. $10 is chump change compared to the value of your vehicle.
