Originally Posted By: Smokescreen
Originally Posted By: Sayjac
New Toyota under manufacturers warranty, 'if' vehicle specs 0w20 'only', you use 5w30, you do so at your own peril. In other words, should something major happen to the engine no matter how unlikely, you assume the risk of defending the oil choice if the manufacturer refuses to pay. You might win, but it will be your time and money to battle them in court, a fight which could be drawn out.
So use 5w30 if choose to assume the risk. Or, use 0w20 while under warranty, then use what you want later. Your call.
All that said, if OM says 5w30 also acceptable then no problem.
Exactly. Fortunately this go round I have the text stating in the OM that 5W30 is OK. At Bitog many of us obsess about using the "best of everything," then feel we have our hands tied behind our backs when the OM states one and only one viscosity or else....... Many want to use a viscosity for our engine based on climate or how we plan on using the vehicle, and want to do so from day one not when the warranty is up.
I "tow and run hard" my Corolla 100% of the time so my 5w30 is "justified"....I haven't run a 20wt since 375mi or 600 kms on the odo. I am out of warranty at 187,500mi or 300,000km and just tried 5w40. OOoo scary...still within guidelines of the world Corolla OM. Wouldn't you know it...my fuel economy didn't change a bit. I just had my 3rd tank of 42mpgUS or 50mpgIMP 5.6L/100km.
Eat it CAFE !
And I used 5-20 in 1978 in my engine calling for 10-40. My MPG did improve, and the engine performed very well, in fact much better in extreme cold temps.
Eat it CAFE !
