So, I was given a few of these from a gear head friend that stumbled upon them. Is it a sleeve of some kind? Thanks in advance. It is 1 3/4" long and 1" diameter on each end.
It's a weld on threaded tube fitting for the end of a tube. If you were building a 4-link suspension you'd use that at the end of the tube then thread a rod end to it.
