Originally Posted By: CKN
If it has an 'E' on the end of the part number, it is not acceptable.
The filter in question has been redesigned and cut apart here on BITOG and found to be good enough for the life of the oil according the OLM.
A lot has changed since the year 2000.
It was the newer iteration with the poppet valve that gave me concern. I'm serious, startup noise like I have never experienced. Like I said, I wanted to think they would be fine, that's why I used them. All I know is what I experienced. Take a look at this TSB, the things are just questionable. They might fit the bill on paper and most of the time, but they just don't have any room for error:
Service Information Home Publications Number Search New Bulletins Bulletin Search Feedback Help
#PIP5276D: SES Lamp P0521 Setting After An Oil Change And Or Low Oil Pressure Indicated On The Instrument Panel - (Jun 8, 2015)
Subject: SES Lamp P0521 Setting After An Oil Change And Or Low Oil Pressure Indicated On The Instrument Panel
Models: 2007-2013 Cadillac CTS-V, Escalade
2007-2013 Chevrolet Avalanche, Camaro SS, Colorado, Corvette, Express, Silverado, Suburban, Tahoe
2007-2013 GMC Canyon, Sierra, Savana, Yukon
with a V8 Engine (RPOs L20, L77, L94, L96, L99, L9H, LC8, LC9, LH9, LMF, LMG, LY6, LZ1)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
A concern of a P0521 Setting After an oil change and or low oil pressure indicated on the instrument panel.
Recommendation/Instructions
If you are working on a Gen4 V8 that is setting a DTC P0521 and or low oil pressure indicated on the instrument panel in cold or hot weather and the engine is currently equipped with a PF48E oil filter, replace with a UPF48R oil filter if one is available.
Note: Only use the UPF48R oil filter if theGen4 V8 is setting a DTC P0521.
Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
4065530
Oil Filter Replacement
Use Published Labor Operation Time
