food grade grease
Knowing nothing more than what I see on the two links, it would be super easy to pick the Jet-Lube. At least it gives SOME properties instead of just saying "biodegradable."
would mineral oil work? the last time i tried on a squeaky door hinge, it squeaked even louder and i had to put 50w oil.
Originally Posted By: bernau
Which of this two greases have corrosion resistant properties or is a better grease?
https://www.amazon.com/Ultra-10340-Bioba...od+grade+grease
https://www.amazon.com/Jet-Lube-30150-Ma...customerReviews
I have them now but unsure what to put my grease gun. using them for general house lubrication like latches etc because i got a toddler.
thanks in advance
Unlikely either have any anti-corrosion additives. Whatever you use, if you are using enough a toddler can get at the lube and consume it, you are using too much or you are not storing it correctly. Not that food grade grease is a bad idea, choose either and use sparingly. That said, Vaseline or wax works in a pinch.
Nice work Pablo
