Hi guys,
What should I be looking at for a Mitsubishi FTO MIVEC used on track?
Engine is a higher revver (8,000+ rpm) but is mostly standard other than bolt ons.
I am likely going to use Shell Helix Ultra I believe, but wondering what viscosity?
I think OE specs are 5W30 due to the high rpm, but wondering if a thicker or thinner oil would be best used?
Engine has been rebuilt so tolerances are tight.
Are there better oils to the Shell Helix Ultra for my application?
