So the girlfriends 2014 Jetta 1.8 TSI has been having two intermittent issues lately. First off the key will sometimes get stuck upon removal from the ignition switch, this is resolved by turning the key back to "run", then turn all the way back and remove. Second, the drivers door lock will squeak/squeal on occasion, I am assuming its the lock actuator. It was at the dealer today for the annual service which included an oil / filter change with Castrol OEM 5w40, a tire rotation and the replacement of the pollen / cabin air filter. She simply mentioned these two issues to them and they actually replaced the ignition tumbler and it was completely covered under warranty. They couldn't duplicate the squeaky door lock but Im not surprised as it normally happens in cold weather. Just wanted to share as these days it is getting harder and harder to get dealers to step up and cover these things under warranty. So thank you VW! Bravo!
