Hey Guys,
I'm new here. I've been doing some extensive research and can't seem to find exactly what I am looking for. I've found some good answers on this site for years just by searching and reading. I'm not coming across the exact situation I am looking for right now.
So, my wife has a 99 Jeep Grand Cherokee with a 4.7L with 156K. It burns (maybe leaks but no dripping, still under investigation) oil...but it seems to get down to about 2 qts low and then it doesn't use any more oil, so it's kind of weird.
Anyway, I just changed the oil in it and while I want to move into MaxLife to help with the seals and such to help slow or eliminate burning, but I had a bunch of 5w20 conventional from a previous vehicle, so I decided to use it up on this oil change even though it calls for 5w30. I poured a bottle of STP in to thicken it up a bit. I still need to pour about 1.5-2 qts in as I didn't have enough on hand.
So, after a lengthy explanation, my question is What should I use for the remaining oil to wean into using a MaxLife formula. I found Valvoline now has a full synthetic MaxLife which I was considering to help create a syn blend since I have the conventional in there, but then the cost of the full syn and the rate it burns, I'm unsure.
Any help on which I should use, or any other advice on products to add, will be greatly appreciated.
Thank You in Advance,
Eric
Eric
