Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
Philadelphia, PA
All mileage is in kilometers not miles. Switched to Red Line D6 ATF.
I'm just looking to get trend lines for metal wear. I've switched to a different oil so don't care about the original formulation.
Understand, but suggest you get a new oil sample of the current oil you just put in the tranny so you know what the baseline values were when you get your next UOA.
D6 is an excellent ATF and I can't see why you would switch.
I don't want to switch away from D6. I just switched to it.
OK, so you didn't switch, but the following statement still applies:
