Originally Posted By: dailydriver
The WEC/ALMS/IMSA/ETC. RACE Ford GT's V-6 Ecotec is definitely based on the street GT's engine,
Generally, this means that the as-cast block and heads are from the street engine, x-rayed prior to machining, but all machining is done with respect to racing use. Good chance of using pressed in steel cylinder liners possibly with nikasil coatings, dry sump oil system, forged pistons, racing ring set, hand ported heads, cc'd chambers, exotic valve seats,...
Forged 4140 crank machined from billet, titanium valves, custom camshafts, custom headers and exhaust, exotic (Motec M8000) ECU, full data collection and telemetry,...
Other than that, its basically stock.
