How many miles do you run that 10w30 out may I ask?
Isn't the sump like 60-70 quarts?
Thanks!
Originally Posted By: TiredTrucker
Yeah, I have taken a couple of semi truck engines to well beyond 1 million on conventional oil. Even the current ones are factory filled with 10w30 conventional. I currently use a 10w30 syn blend from Schaeffer. Mobil Delvac Elite 10w30 is a outstanding oil also. 557,000 miles on the current motor and runs like a champ! Only repair has been for broken exhaust manifold bolts.
Now to be fair, gasser turbos do endure some higher EGT's than their diesel cousins. I would be incline to go with a full syn for turbo gasser. But still, a 30w should be quite sufficient for all situations.
Thanks!
