Originally Posted By: userfriendly
I don't like using me, myself and I.
The question was not what I would do, but with the two choices given,
I would go with 15W40 "conventional" instead of 5W40 "synthetic".
There's a school of thought that synthetic, with it's high VI, will have a flatter viscosity curve, and "protect" more at higher temperatures...big end is considerably hotter than the bulk oil temperature.
So a 5W40 synthetic SHOULD be better than a 15W40 with it's higher slope, shouldn't it ?
I think you are hinting that the 5W40 synth would have an HTHS of 3.8 typically, while the 15W40 is likely around the 4.4 range.
So regardless of the synthetic having a higher VI, and clearly better KV150, the 15W40 will do better at protecting the big ends.
As to what's too hot ?
oxidation resistance needs oxygen, and most of the crankcase ventilation systems I'm familiar with these days don't go sending fresh air in to wash through the flying hot oil like they did in the early days...yes blowby gasses are harsh also.
